Constraints question
neil_prestonneil_preston Member Posts: 12
I'm fighting with an unconstrained portion(s) of a sketch.
The problem is with a simple triangle.  I have tried all kinds of dimensioning, and it will not resolve.
The sketch is on the front plane, normal to the face of the body.  The triangle has 3 sides, and any additional dimensions are light grey, indicating overconstrained.
There is an equivalent triangle on the other parallel face of the body, and it has the same issue(s).
I'm also having issue when I try to extrude, but that may resolve when I get this figured out.
Can anyone tell me what I am missing?
  • MichaelPascoeMichaelPascoe Member Posts: 2,814 PRO
    edited November 2023
    Hey @neil_preston, it is missing constraints, most likely coincident or pierce. There are several things to consider when constraining. Rarely is it a bug, though I have seen them with the sketcher.
    Please share a link to your model so we can help you better.
    RENDERCAD
