translate/ copy to multiple mate connectors
jr_vrvrkn
Member Posts: 125 PRO
Hi,
Is it possible to transform/copy a part to multiple mate connectors at once? I only seem to be able to do it one by one?
And if possible to select multiple mate connectors, can you also account for configurations where you can have more (or less) mate connectors to appear (depending on the configuration made) eg copy to all mate connectors created by a certain feature or features? example: pattern to mate connectors | Part Studio 1 (onshape.com)
thanks!
thanks!
eric_pesty
Member, pcbaevp Posts: 2,529 PRO
If the point pattern doesn't offer quite enough control, you can also use the excellent "Transform Pattern" FS:
https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/v/8217d6d96ccc324b8dd86160/e/4c62c06c4e0e4db3703a2d4c
keep in mind this is actually a simplified version of the real part.(which I can't share) in which parts are added to a curved surface (and oriented normal to).
thanks again for the help! But not quite there..
thanks!
edit: worked like a charm.
Thanks!
