Size changes when export from OnShape
settanan_plangsiri
Member Posts: 4 ✭
Hello! I am very new to OnShape and 3D design/printing, so I truly apologize if this question might sounds stupid.
Currently, I am facing an issue with exporting my design in the .STL file. So I created a design with around 600um height but when I exported it and open in Blender... the height of my design became 15-16cm instead. I had made sure that the dimension that I use is similar to when I click export (centimeters).
I had also try sending my .STL file to one of the 3D printing services. The reply I got was that the size was not specify in the file which is very baffling to me.
Is there a way to make sure/verify that my design is the correct size as what I planned to print is quite size sensitive! (Or is there certain file that you might recommend that would contain the size of my design?)
Thank you so much!!
Thank you so much!!
martin_kopplow
Member Posts: 1,442 PRO
Usually, if the scale error factor is suspiciously close to 2,54 or 1/25,4 (as in this case) then the issue is with metric to inch conversion. Try adjusting the settings in both applications to be identical and watch out for an additional scaling factor setting, which might exist independently from the unit setting. Unfortunately, some applications seem to ignore units stored in the file: Some do not write them and others do not read them. Some applications just assume, the units in the imported file are always inches, no matter what is written into the file. In these cases, it is sometimes wise (though not necessarily right) to export in the unit the receiving app assumes.
1
Thank you so much!!!
