How to fix the roration sweep along a 3D Spline
alan_curley
Member Posts: 7 ✭
Hello
I am trying to design a part with a cam track for generating a reciptocating motion.
I've a cylinder and I've managed to add the 3D Spline to represent the cam profile.
I've added a rectangle to represent the cut profile
When I try to sweep my rectangle profile around the spline to cut my channel, the square profile also rotates, twisting and not creating a proper channel for my cam (See attached image).
Can anyone help me? Any of the tutorials for this (that I can find) offer a circular profile so this is hidden.
The part is at: https://cad.onshape.com/documents/1447003c61663834aab9c49f/w/1710d7dda387e9c3d6c9fe79/e/e1929228c4da4196c4b7155f
https://cad.onshape.com/documents/5dbbf994f78b8c568b66a641/w/20fcc795a4dd730592c52285/e/b6473ae729dc36847365486d
I also tried extending the shape before wrap but i couldnt get the spacing right for the shapes to merge cortectly. When I added the extener rectangle, the wrap and the extrude fail.
When I worked up a sample a while ago for my edification. The form was laid up with sketch a calculated length.
Some variables were used for the tube and sketches.
Sry. Can't find the sample. Either deleted or placed deep in another document. If I can find some time in the morning maybe make a new one unless somebody has another sample.
Here is a sample thrown together. You'll notice that the first 2 profiles are shortened by a small amount and the tag removed after. When the profile ends meet there seems to be an error such as nonmanifold geometry.
You can continue around as noted in 3rd sample.
https://cad.onshape.com/documents/5b39ca64fc6d7068af614a4a/w/a3f3bb9d91381c69586e09e7/e/6c67233cf933fbe625fd8a53
Hope this helps. Glen
