Trouble with Extruding Airfoil Design into a Ring for CD Turbine - Missing Walls in 3D Print Export
toby_weitoby_wei Member Posts: 2 EDU
Currently, I'm making a ring to go around a CD with slots so that I can insert turbine blades into it. When I tried to extrude the airfoil (using the NACA profile generator) into the existing ring, however, the solid wall disappeared. When I export the file for 3d printing, the walls are also not there. Attached below are screenshots of before the extrude, the after, and what it looks like in PrusaSlicer. Any help would be greatly appreciated!
  • glen_dewsburyglen_dewsbury Member Posts: 1,295 PRO
    If you share a link to a public document it will be simpler for some one to analyze your issue.
