Can't loft a polygon to rectangle
Hi!
I'm wondering whether Onshape can handle lofting a line into a point or not. I would need the loft to make a triangle as shown in the picture. It only seems that Onshape loft can't make that. Is there a way to achieve this?
  • MichaelPascoeMichaelPascoe Member Posts: 2,817 PRO
    edited December 2023 Answer ✓
    Hi @oskari_pere, while using Loft, there is an option to match connections. Once you match your first connection, you can collapse it to add another connection. This should allow you to achieve what you are trying to do. Alternatively, you can also use guides.
    RENDERCAD
    RENDERCAD
