Extrude removing material in Sheet Metal part
Roberto_Verduci
Member Posts: 29 ✭✭
Hi,
I'm new in scripting.
I'm tring to sketch a circle on a SM face and to extrude it removing material. I can draw a circle, I can extrude it but I get an error with opBoolean (@opBoolean: SHEET_METAL_PARTS_PROHIBITED).
How can I use opBoolean with SM?
Thanks
Thanks
The easiest way to do it is to use the actual Boolean feature instead of opboolean. It handles all the hard stuff for you.
thanks. Where can I find an example? I'm new in featureScripting and I'm learning step by step
if your opBoolean Call is similar to this with no other arguments
then change it to
this should solve your issue
it was so simple that I hadn't considered replacing the feature name
It works good.
Thank you both!!
