How to define an offset between a cylindrical surface and a flat surface
XXXXX
Member Posts: 3 ✭
I'd like to assemble a cylindrical part so that it is centered between two flat surfaces, not sure which mating tool I should use.
Not really sure - does the cylinder touch both plates? Are the plates parallel? Is the distance between the plates equal to or greater than the cylinder diameter? Does the diameter determine the distance between the plates? If parallel and further apart than the diameter, is the cylinder centered or resting on on of the plates?
Help us help you
Yes, you have a perfect storm here - no easy way.
A number of solutions are probably workable.
1) Import a sketch into the assembly - mate the blocks to each side of an entity in the sketch and the cylinder to a mate connector at the mid-point of an entity.
2) If the distance between the blocks is known, then in the part studio defining the block, create a mate connector that is offset by half the distance between the blocks. Then in the assembly, just mate the two mate connectors together to position the blocks and then use the same mate connectors to the position the cylinders.
3) position the blocks offset from mate connectors generated on the cylinders.
3 Is my favorite (but they would all work) - here is an example.
https://cad.onshape.com/documents/08b545acfdaf072292119fc4/w/e4666214273adb79c0abccaa/e/1442a5cd641673753a3c6944
Please feel free to create/vote for an Enhancement Request that is a 'mid point' mate.
1. Create a point on the circle in the sketch you are using for extrude or create a new sketch with a circle and point.
2. Then create a plane using the Plane Point method with that point and parallel plane.
3. Create the sketch on this plane and define any point on it (center one in my case)
4. Create a mate on this point.
5. Profit!
