Rotating to snap points
in Drawings
Hello, I only started using Onshape a few days ago and I can't seem to nut out how to rotate to snap points, or if you actually can. At the moment I'm snapping the sketch to a corner and then manually using the transform tool changing the angle until it lines up. Surely there is a less time consuming, accurate and easier way to do this. Help is much appreciated.
1
https://learn.onshape.com/catalog?labels=%5B%22Self-Paced%20Courses%22%5D&values=%5B%22Assemblies%22%5D
