how to constrain part to be horizontal in assembly
jeff_mcaffer
Member Posts: 94 ✭✭✭
Bit of a whacky case... I'm creating a jig to cut a compound angle on 1" angle iron part (strut). The saw only has one degree of angle (miter saw not compound miter). But by dialing the right miter angle and "pivoting" the angle iron along it's long axis on the saw bed, I can get the same effect. Problem is I need to figure out how much to pivot so I can build a jig to hold the material in the saw. See e30 engine bracket | Assembly 2 (onshape.com). In that example I've got the part, a section of saw blade (band saw) and a representative vice jaw.
So I want to place the part in the assembly such that one of the leg outer edges is "horizontal", that is, at least parallel to the bottom of the blade part and the compound cut end face is "flush" with the blade face. That should force the strut (angle iron part) to pivot along it's long axis. My jig then is just a triangular wedge that fits up against a vice face.
So far I've revolute mated the face of strut to the face of the blade. That makes sure it's flush with the cut. But since it has to go in the saw "horizontal" I need to rotate the part to get it lined up with the top/bottom of the blade. I've eyeballed it but there must be a better way. Any suggestions on how to constrain the strut part here? A different approach?
martin_kopplow
Member Posts: 1,067 PRO
Thanks for keeping us updated, for this appears to be an interesting case.Using the formula is probably a good thing. You could even put it into a spread sheet, provide input fields and result output fields for the users in the shop and use that document whenever needed. (Google says there are already quite some of these spread sheets out there ...)I would have expected this worked with mates, though, but when I tried yesterday night, I also struggled. I am quite sure I used a combination of mates that should do the trick, but OS did not resolve them. Maybe we were too much focused on recreating the workshop setup in 3D, while this was a pure geometry problem. So I tried to do it in the strut's part studio instead, using only planes and projections, which got pretty complex after while and one would not want to do that over for all possible jigs required. Still, I provided some valuable insight: I was being stupid.I still believed it should be feasible in an assembly, and most shops prefer a visible representation over numbers anyway, so, after throwing away all unnecessary stuff and understanding the geometry, I tried again, and now it was in fact quite simple. I used the simplified geometry on the strut and voilá:
Only two mate conditions:1. Cut face of strut planar with blade2. Lower (or any long) edge of strut tangent with workbench
In this pic the black bit is the blade and the blue/gray bit is the strut. The orange blocks are there to represent the saw vice. See e30 engine bracket | Assembly 2 (onshape.com). So the top of the blade is horizontal and I've purposely revolute mated the part to the side of the blade with the connector such that the "corner" of the part is on the top edge of the blade. So in theory all I have to do is constrain the V edge (leftmost in the pic) to be on the same plane as the blade's top face. The mate connectors on the strut are all "askew" as the part has been rotated so whenever I try the mating the system ends up over constrained in some way.
Is there a way to mate a point to a plane regardless of orientation?
I'm starting to wonder if I'm just approaching this wrong and could/should be doing something in the part studio where I can use full on constraints...
The biggest issue is the eyeballing of the revolute rotation to get the strut horizontal. That was very tedious and just feels wrong in terms of engineering. Thus the question of how to actually constrain it to be horizontal in the assembly. The manual step of measuring and carrying back the axial rotation angle as input to the jig part is annoying in that it's not automated and so doesn't scale and will get forgotten as the model changes (e.g., the strut design changes or many struts are needed and we have to remember to do all this again for each strut).
So I think I need to look at this differently and do some math etc in a part studio to figure out the angles and generate the appropriate jig which is inserted and fastened as you described.
I'm still interested the original problem (constraining the strut to be horizontal) as frankly mate orientation has long been a challenge for me to understand.
As for the vice, yeah, I can see the confusion. Turns out there are different designs and mine happens to work the way I drew it (the jaws close on a fixed linear rail parallel to the blade and pivot to the make the desired angle). Either way the problem here is the same.
There must be something basic I don't understand about mates as this sort of thing has always been a frustration for me. For example, here if I planar mate the "top" corner of the strut end face to the top of the side face of the blade that's great. Then I'd like to mate the other end of that top strut edge (or the whole edge) to the plane of the top of the blade forcing it to be horizontal. I just want that end vertex (or edge) to be on that plane, don't care if the axes align (in fact I know they won't). However, the planar mate wants to align the axes thus over-constraining the system. It's like I want to "nest" or "stack" mate connectors -- put a ball connector on a planar connector. That way the ball connector itself can slide around on the horizontal plane but the strut (mated via the ball) is free to rotate. I don't see another mate that has similar behavior. Somehow this must have come up/been solved.
After consulting with the math folks on Reddit, it turns out that the tilt angle (phi) and axial rotation angle (theta) can be computed based on the lengths of the horizontal intersection edges as follows:
- phi = asin(1/sqrt(#A^2 + #B^2-1))
- theta = asin(sqrt(#A^2 - 1) /sqrt(#A^2 + #B^2 -2))
Concretely phi is the angle of the saw vice relative to the blade and theta is the axial rotation of the piece in the vice. Using theta I can create the jig block as a part and insert that into the assembly along with the blade and vice jaws. Then mate those up and bam. See e30 engine bracket | good (onshape.com). Note the assembly is more for visual verification. I just need to gen drawings so production folks can make the jigs and cut the parts.That computation is a bit yucky to do in variables so I'll check out writing a bit of FeatureScript as I have to do that at least 3 more times and possibly many more for different devices.
I still struggle with mates and orientations. 30% of the time parts get unwanted rotation when mated, 30% they don't get rotated (and I want them to), and the rest of the time the situations are simple and all works fine. I've watched a bunch of the videos etc but somehow just am not grokking something fundamental. Pointers appreciated but I'll muddle along.
Thanks folks.
As for the spreadsheets etc. Right. For now I wrote a little FeatureScript that does the math and adds phi and theta variables to the part studio. I really want to import those to the assembly (that seems no possible) but I can avoid needing them using mates (as you have demonstrated).. Related, when you said "Google says there are already quite some of these spread sheets out there ...)" what search terms were you using. I had poked around before starting on the math direction but didn't know what to look for.
Again. Thanks for digging into this. Folks like you make the onshape community so awesome.
Creating the assemblies was more finnicky than I'd like but workable given it's only a handful of mates. In reality I don't need to do assemblies for the cutting drawings. I can make parts using the phi/theta angles computed and add those in the drawings. Still super useful to be able to have some assemblies examples etc.
Thanks again for the help.
