Place ribs inside of tube that has a lofted taper
This tube is to be 3d printed and need more internal rib stiffeners
I can't get the ribs to follow the curvature of the inside of the tube that was first lofted and then thickened.
The ribs are ok at the bottom but only go straight up and don't follow the wall profile.
See the file
, resulting in non radial symmetry for the loft resulting in a more complex shape when you try and create the ribs:
Here is a way you can accomplish the desired part I think you're trying to do: https://cad.onshape.com/documents/219d02491fb79ba022fb414d/w/9dbc04c2618bf6653e3e3977/e/a5b01df8a5c05426ec0773b2?renderMode=0&uiState=657234dfd735724c7fcaf9f5
