Adding Radius edges, limiting the length, and transitioning the ends.
patrick_shea
                    Member Posts: 63 ✭✭
                                  in General
                    Trying to simulate Radiused Edges - using a router bit on woodworking projects.  I did a little step (0.005) on the edge to limit the length, but can I transition to simulate the bit diameter?
Shuswap Pat
                        Shuswap Pat
It's easiest if you create a construction sketch to pick the axis:
https://cad.onshape.com/documents/770c9a212c05dcfee874c102/w/e964fb5663168eae96d3ae10/e/25e8222c6e61354ad01a0e09?renderMode=0&uiState=656e1ddf2f154b447262462d
