How to copy extrusion features to all faces of a part
Hello!
I am trying to replicate holes onto every face of a cube, see the project here: https://cad.onshape.com/documents/edd2c2326d091f4f6d65ee11/w/e42dfe5f3556605262b9c3d7/e/f5b0640142f49831cf15819d?renderMode=0&uiState=6584b5383de095154ce97ed3
I managed to mirror some of the holes from the front to the back, but am clueless as to how I will get them onto the left and right sides...and then onto the bottom part.
I did not start this project, I am finishing it for someone else and have near no experience with onshape.
Any help is appreciated!
  • brianna_sankobrianna_sanko Member Posts: 2 EDU
    I think I can use circular pattern?
  • Robert_ZettelRobert_Zettel Member Posts: 3 PRO
    you can also create a Plane  between the sides you like to mirroring !
  • glen_dewsburyglen_dewsbury Member Posts: 1,266 PRO
    Absolutely. Make one set of holes for a side pattern and the holes for one quarter of the top and them you can circular feature pattern all the holes with the rotation axis at the center of top face.
