My Polygon Pipe Feature Script
eldon_brown
Member Posts: 50 ✭✭
I am still trying to learn Feature Script, but have something that others might enjoy, it is my FS "Polygon Pipe", it can be see at:
https://cad.onshape.com/documents/0674326b738e87464861ebf4/w/47924d3827167a01698cfcd2/e/3b0b399cb136bda858d54637?renderMode=0&uiState=658544db28d9942be73dbddd
Any line, object edge, or path can be used to create a solid or hollow Circular, Rectangle, Regular Polygon, or Slot pipe, other forms are planned.
At the current revision, Rectangle can be offset from the path, via distance or Quadrant, Polygons can be rotated via an angle (more to follow).
The following shows some of my interesting uses and test cases.
This FS is still a work in progress, but usable, and with more to come.
Any programming help, uses cases, or ideas would be welcome.
Thanks,
-Eldonb
Thanks,
-Eldonb
4
