Naming new Sketches, Extrudes, ....
klaus_krämer
Member Posts: 93 ✭✭✭
in General
For better documentation, first step when I create a new sketch, extrude or something similiar is to give it a name before doing anything else with it. Sometime I even begin typing - with not so amazing results ...
Opening an new such thing (don't know the word for all the tools together) should result in first naming it. What do you think?
Adding features should be quite similar: Name it first and then go to work with it ...
Yes, it's easy to name features - but that's not the issue. It's about opening a new feature with the cursor ready in the 'Name' input field right after opening.
This is quite good for these features, although "ThreadCreator" does not update the name if the dimensions of the according surface are altered - which makes the automatism unreliable.
I'd rather have an option in "Preferences" to activate a mandatory naming of features. You could always press Enter for the default proposal.
