What are Best Practices, regarding Variable Table vs Variable Studio ?
eldon_brown
Member Posts: 50 ✭✭
What are the advantages and best practices regarding use of "Variable Table vs Variable Studio"?
Are Configuration Variables different?
Does a variable with the same name in each override the other?
I have search for this info, but still confused.
Thanks,
-Eldonb
Thanks,
-Eldonb
_anton
Member, Onshape Employees Posts: 524
For most purposes, you can just use the variable table panel in a Part Studio or Assembly. The only nuance here is that you may have imported only a subset of variables from a Variable Studio, in which case the table won't show you the rest.
And yep, the override rules are as you describe (note the info icon next to the overridden variable name).0
A variable table makes it easy to view and change variables. It's the tab you can see on the right edge of any Part Studio and Assembly, and the entirety of a Variable Studio; it's the typical way you'd want to interact with variables. In some less-common-than-average cases, you do need to know that Part Studio variables are actually created and changed in features.
Configs are conceptually different - while normal variables can be viewed as an internal part of your design's definition, configs are normally viewed as external inputs. Imagine a part studio you're deriving into another document; you see its config variables then, and you need to specify their values in order to actually create the part. Of course, this definition can get blurry.
Yes, there are some override rules. When you import a Variable Studio, the variables are essentially declared in the order shown in the variable table, so later definitions of a particular variable override the ones higher up.
Things are getting clearer, but I am not out of the woods, yet.
Thanks,
-Eldonb
