how to align features with parts?
job_van_der_loo
Member Posts: 5 ✭
Hi!
I'm modelling a bench (first thing I ever CAD'ed). The bench needs holes on the bottom side to attach the legs of the bench with dowels. Now I struggle to find the correct locations for the holes since I only have 1 leg in my part studio. Ideally, i'd make the holes in the assembly studio when I know where the legs are going to be. What's the best/ easiest way to do so?
Thanks!
Thanks!
glen_dewsbury
Member Posts: 1,223 PRO
There is a way to do this quite nicely. I didn't mention it earlier since it is usually considered an advanced method. (you mentioned being a novice)
My sample is changed to use in-context editing so that legs are placed in assembly using fastened mates. The holes in the table top use in-context edit to transfer hole positions that follow the legs.
Try changing the position of the legs by editing the mate connecters.
https://cad.onshape.com/documents/15d8b7aae32367e74486fbc6/w/807b1dce7ffaec6a27cf88db/e/cff4795fdc9b32dd542fc87b
I recommend some study before trying to use this tool.
https://learn.onshape.com/learn/course/managed-in-context-design/completion-certificate/completion-survey?page=3
When you make the assembly you'll reuse the leg and mate the legs to the different locations.
