How to move a sketch object point to a typed position
robert_kluttz
Member Posts: 4 ✭
For line endpoints or arc or circle centers, how do I move those to
a precise TYPED location in my sketches. Nothing will let me type them.
I can see the coordinates in the bottom right but it won't let me edit those as either absolute coordinates and I can find no way to use them relative to any other point either. Is there no relative position feature like in Autocad... i.e.
move a point to a position relative to another point without having to
calculate absolute positions? Nothing I can find will let me move a
point once it is placed other than dragging it to an arbitrary location which is frustratingly imprecise.
It
really seems like once a point is in you should be able to edit that
point using 2 different versions of location, either absolute to origin
or relative to another defined point. I can't find any way to get either
one to work or how to do it.
For example... If
I have a rectangle with corners a 0,0 and 48,48 and I want to create a
line that I will use to chop off a corner of the rectangle and I wanted
that line to go from 0,20.125 to 20.125,0
For
2nd example, the same thing but for a rectangle the same size that does
not start at the origin point. How would I do the same thing relative to
the bottom left corner?
Normally you type in "locations" by adding dimensions to sketch entities. That said, within the sketcher there is a transform tool that will move things by numeric amounts. You can change the reference point of those moves in order to do many of the things that you're looking for.
https://learn.onshape.com/courses/fundamentals-sketching
https://learn.onshape.com/learn/learning-path/onshape-fundamentals-cad
