QR Code feature
_anton_anton Member, Onshape Employees Posts: 538 image
edited January 2024 in FeatureScript
Feature link: https://cad.onshape.com/documents/590aa2e4425ab6d582393356/w/81d6535fe1c9afe3c44a3424/e/98a77b1588b0b49a23f1a7dc
This feature extrudes geometry representing a QR code.
Notes:
  • Only "normal" ASCII characters are supported as input. No Kanji mode. No micro QR codes.
  • At the end of the feature dialog are some preview and generation options. Creating the geometry is off by default.
  • I recommend setting up the rest of the feature before you create the geometry because extrude-adding a QR code turns out to be way slower than extrude-removing.
