QR Code feature
_anton
Member, Onshape Employees Posts: 510
Feature link: https://cad.onshape.com/documents/590aa2e4425ab6d582393356/w/81d6535fe1c9afe3c44a3424/e/98a77b1588b0b49a23f1a7dc
This feature extrudes geometry representing a QR code.
Notes:
Notes:
- Only "normal" ASCII characters are supported as input. No Kanji mode. No micro QR codes.
- At the end of the feature dialog are some preview and generation options. Creating the geometry is off by default.
- I recommend setting up the rest of the feature before you create the geometry because extrude-adding a QR code turns out to be way slower than extrude-removing.
I have several places that I can already use this Q-Code Feature, as raised letters on a 3D Printed white surface.
Thanks,
-Eldonb
Legit! Nice work @_anton
Thanks,
-Eldonb
