How to make a flange - I can't select the edge when prompted
As the title says, I can't select the edge I want from the sheet metal I've thickened or extruded (tried both).
Red arrows indicated are the edges I want to make a flange from. What am I missing?
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 561 ✭✭✭
    edited January 2024
    You used ticken, but you must select the Sheetmetal first and create the sheetmetal part
  • wayne_sauderwayne_sauder Member, csevp Posts: 627 PRO
    @haurjie_liang
     You will need to make a sheet metal part first (I would replace your thicken with a sheet metal model and use thicken in that tool). The flange tool only works on sheet metal parts.
