How do you fill in a hole in a sheet metal part?
shawn_crocker
Member, OS Professional Posts: 925 PRO
I used to use the tab feature. I would draw a sketch over the hole and then use the tab feature and it would fill in the hole. Now, it seems the system is blocking tab from being used in this way. Also, can't use delete face with the heal option. I'm feeling surprised there is no way to remove a hole from an active sheet metal model(anymore).
John_P_Desilets
Onshape Employees, csevp Posts: 271
Another option you can use is the move face feature. If you move the face inward you can close the hole. However, you cannot apply an end condition for the move face feature so it can be less stable.
John_P_Desilets
@shawn_crocker I was able to use the tab feature with this example. Can you try to make the sketch on the opposite face of the sheet metal part and try again?
That not working for some reason.
Still no worky. I'm getting the same message.
Doesn't work with sketch and constrained circle. I normally just do a use command on the existing edge. I started trying with a circle but tried with just an open sketch in the video because it seemed to be suggested by @Cary_Bettenhausen
They are coming from a hole feature that has been patterned. I will often pattern out some holes and then just go back and delete a couple that I don't want part of the pattern. In the past, I have had no issue using the tab feature to fill in the un-wanted patterned holes on an active sheet metal model. Of course, I do want this op being done on the active model because I don't want them showing up in the flat pattern.
Actually, I just noticed the move face workaround isn't working either. The move face feature isn't allowing me to select the face of the hole. I think this is a new bug or something because I definitely have been able to use move face on hole faces on active sheet metal
Hi John. I think this post is related to the ticket #338178.
