How can I do lines in the middle of my fillet's?
daniel_mckenzie143
Member Posts: 5 EDU
Hi guys, Im designing a cube which opens out into its 6 faces. I've filleted all the edges of my cube but I want to draw/have some lines on the vertex to show that it is a connection point between the faces. Any help with how to do that?
dirk_van_der_vaart
Member Posts: 561 ✭✭✭
Or just design 1 panel and then Mirror and Rotate+ copy.
https://cad.onshape.com/documents/642a2b04554099e722899e45/w/25e79f6bd9e728ffa8ef37fd/e/65e829b152c857753dc93184
Feel free to copy and edit.
martin_kopplow
Member Posts: 1,285 PRO
daniel_mckenzie143 said:Hi Martin, thanks for the reply! Im semi-new to Onshape so I'm still learning. How do I split the filleted parts?Hi Daniel,typically, with models consisting of several identical elements, you would only design one element and then reuse that as often as required. A cube can, for example, be broken down into 6 pyramids, their tops meeting in the cube center. A pyramid then is but a square and four triangles. If you follow that approach, You'll have much less work, plus you get the 'lines' you want for free.If I model but one cut-off pyramid, I get all the planes needed to split a cube into whatever elements I need, and to subsequentially rebuild it from those parts:
1
