Sheet metal thickness custom property computed value.
I've created a custom feature for the thickness of a sheet metal part (to be used in a BOM). Currently, you have to type in the thickness manually but it would be nice if the value could be computed.
If you set the thickness of a sheet metal part to be 3mm, I am curious how you would get this value in a custom feature to be used as a computed value.
I have made/modified a couple of custom features before but I am far from an expert. Thank you.
I would like this thickness value to be used in a custom feature.
I would then use it to compute the value of a custom property.
https://cad.onshape.com/FsDoc/library.html#setAttribute-Context-map
And then in your computed part property, just read the attribute back out.
Or, instead of using a computed part property, just use a normal property and set it with the featurescript.
https://cad.onshape.com/FsDoc/library.html#setProperty-Context-map
SetProperty can set the value of a custom property if you have the property id.
