Sketching tutorial
yat_cheung_wong
Member Posts: 7 ✭
Hi guys,
I tried to follow the sketching tutorial:
https://cad.onshape.com/documents/c98978894f544f89aa10633f/w/a099a1f1c6234125997b78a2/e/8f07cba71d16411faf603050
but when I used the Trim command, I can't trim exactly what I see in the tutorial. It trims the whole line instead of the segment up to the first intersection. I can workaround by add an extra horizontal line in the sketch, but that's not what the tutorial shows:
Any idea? Did I miss anything? Will be very grateful for any help.
Thanks,
-Ivan
Thanks,
-Ivan
1
andrew_troup
Member, Mentor Posts: 1,585 ✭✭✭✭✭
@yat_cheung_wong
I wonder if what you are considering an intersection is actually the edge of the underlying solid model?
Because trim only considers intersections within the sketch.
You would have to first "Use/Project" the model edge if you want to trim to it.5
Thanks,
-Ivan
