create plane between two points and normal to curve
evan_phinneyevan_phinney Member Posts: 6
edited January 2024 in Community Support
Is this possible? Maybe with a feature script?
I know about curve point, but I would like for it to be on two points either side of a spline curve and I can only pick one or the other. I would like the plane to be normal to the main curve where it passes the points.
  • eric_pestyeric_pesty Member, pcbaevp Posts: 2,472 PRO
    Here's one way to do it (at least I think that's what you were asking)...
    It does take a few steps to get construction geometry in place, you can use either the plane with point curve or the multi-mate connector FS which lets you re-orient the secondary axis which might be helpful if you want to sketch on there after...
    https://cad.onshape.com/documents/9d6b2a5e3c8701a552458cbd/w/33dedbaf633ed2e9281ea224/e/9561dba6f414c74135f3d02b
    However I don't have any context for what you are trying to do but I wonder if it wouldn't be easier to try to define a plane first and create your curves afterwards...
  • evan_phinneyevan_phinney Member Posts: 6
    @eric_pesty that is close but not quite it. And I think I have figured it out... Brainstorming yay!
    If you  look in my linked document it has been completed to my liking. I created a 3D Fit Spline between the two outer endpoints, made a Point Normal Plane midline on that curve. Started a new sketch on this plane and projected the middle curve and one of the outer ones onto the sketch. Then with a creative use of the Trim tool I got an intersection point, plus the end point of the middle curve. Then just a quick line for "normal" reference for the new plane. Finally, a Curve Point Plane using the midpoint of the previous 3D spline, and the line made in the last sketch.
    In the actual PS I'm working in, the curves are already defined and cannot be changed.
    @evan_phinney
    Glad you figured it out. The "sketch6" mate connector in my sketch is actually what you were looking for I think. Similar process except I skipped creating your "plane3" by using an MC directly. And I just created a line segment "normal" to the middle the curve (instead of a convert/trim)
