"Typecheck canBePlane failed", error creating a plane
Mohamed_AlieddinMohamed_Alieddin Member Posts: 5 PRO
edited January 2024 in FeatureScript
Can someone help me with this error? it is still creating the plane but failing to sketch on it!!  the millThcik is containing an input in millimeters.
UPDATE: The issue is resulting from using a valuewithunits instead of an integer, I resolved it by dividing by the unit of measurement. However, I am not able to sketch on the resulting plane and the part is failing!.
  • ilya_baranilya_baran Onshape Employees, Developers, HDM Posts: 1,255 image
    It's actually the other way around -- the position of the plane origin should be in length units (makes sense if you think about it), so it should be:
    plane(vector(0 * meter, 0 * meter, mthick), vector(0, 0, 1))
  • Mohamed_AlieddinMohamed_Alieddin Member Posts: 5 PRO
    Thanks Ilya, this is resolving the plane-creation error. However, I am still struggling with the creation of a sketch on this new plane! I think I am doing something very wrong in here:
    Yeah, doing it this way you need id+"plane1" in the query instead of makeId("plane1")
    But in a custom feature, it's just much better to not create an actual construction plane and just use newSketchOnPlane
    Thanks Ilya, this was helpful.
