Is it possible to convert a document from metric to inches
paul_bartlettpaul_bartlett Member Posts: 98 ✭✭
I have downloaded a public document and would like to convert it from metric to inches. Is there anyway to do this
  • MichaelPascoeMichaelPascoe Member Posts: 2,803 PRO
    edited January 2024 Answer ✓
    If it's an import in Onshape, select the tab where the import is and it will allow you to change the units.
    If it's an Onshape document that someone else made, you can change the workspace units using the menu at the top left of the screen.
    RENDERCAD
    RENDERCAD
