I'm trying to create a sweep along the surface of an outer cylinder on a curved object.
koki_okoshikoki_okoshi Member Posts: 5
I'm trying to create a swept object along the helix of an outer cylinder on a curved object to create a ditch.
However. it doesn't generate one properly for unknown reasons, and I've been stuck for more than 2 hours.
I've already tested out several ways to adjust the position of a graphed triangle but to no avail.
I would be very appreciative if anyone could help me solve this problem as this is pretty urgent.
The error code says "Swept 1 did not generate properly; Could not create a valid swept body, check input."
Here's the link to my Part Studio:
https://cad.onshape.com/documents/1014749151f35a39edc72c66/w/48176e670c5dcde4ea151154/e/378014e07afff1127e6a025f?renderMode=0&uiState=65b244c0cac8940ccef52701
Thanks,
Koki
bject
