Question about Architectural design within onShape
Hi onShape community!
I'll consider myself as a good enough 3D CAD designer in order do realise any mechanical (or other kind of) 3D part desing with onShape but... I'm kind of totally nooby about arch(itecural) design ; and of course I'm in need of this for a personal project.
my purpose : generate a *.dwg for a building interior layout creation (in order to provide it my architect).
I 100% suceeded drawing in a part_studio a 1st sketch for the "walls".
I have created a 2nd sketch (to be considered as a 2nd 'layer'), in order to design the internal partitions of the inner wall spaces. It was awesomely easy & fast to do, with a very efficient way to optimize the future implementation, simulate different variations of wall length,... .
At this stage, I've created a Drawing... and here comes the problem:
Do somebody have already encountered such a case?
What would be the best practice in order to have as a final result a *.dwg file for a global skecthes output?
Any tips will be appreciated!
Thanks in advance!
- I'm able to insert as 2 individual "drawing plan" my 2 sketches... but they are "unlinked", meaning I have to move & adjust with the eyes the inner partitions sketch upon the walls. The bad point here is that even if I've reache a nice level of position adjustement between the 2 sketches, I can't make any Dimension drawing between entities which are not part of the same "drawing plan" (which is of course what I want to do
- I've tryed to 'Copy sketch' / 'Paste sketchs' from one to another... result is a total mess, too long to manually readjust.
- I've tryed too to 'merge' the 2 by an intermediate Assembly... which works fine (from a visual prospective) as an assembly.... but which give a "empty" visual result as soon as I'm trying to inject it in my drawing.
Thanks in advance!
https://thesmoothcut.com/
...And I just found the contextual menu "Hide/Show > Show sketches"... which makes the magic happens: it works fine!
