How to determine the kind of object selected by the user?
joshtargo
Member Posts: 454 EDU
I need to get a direction vector. if the user selects an edge I can do it, if they choose a face i think i can use the normal to do it, but how do i determine the type of object the user selected so i can apply different code?
this is to align a new mate connector's Z axis.
annotation { "Name" : "Direction", "Filter" : QueryFilterCompound.ALLOWS_DIRECTION || BodyType.MATE_CONNECTOR, "MaxNumberOfPicks" : 1 } definition.myDirection is Query;then later you can use the https://cad.onshape.com/FsDoc/library.html#extractDirection-Context-Query
e.g.
...then it works very cleanly.
will extractdirection work for either of those picks?
https://cad.onshape.com/documents/d57ab129ace0b2436049095c/w/bb8f5d1770f7c22ad70c7906/e/a199adf0f34542c09f8a1678
