How to align imported (derived) part with domestic one in PART STUDIO?
I have a bar with two holes as imported part, a bar with one hole as dometic part and i want to align them so the hole on domestic is concentric with one hole on imported + imported and domestic bars are paralel.
So, first I transform one of them by mate, hole to hole of another one.
Then I have to rotate one of them, but I don't know how to rotate it exactly to be paralel with the other one. I know how to rotate it by hand, but that wa i can not make them exactly paralel.
I know how to do this in assembly, but I need to do it in Part Studio, because I have to edit something else depending on imported(derived) part.
Thx in advance
Thx in advance
S1mon Member Posts: 3,315 PRO
I use the Point Derive feature for this:If you need to do this with derived sketches, Transform Pattern will move them:
https://cad.onshape.com/documents/25a0a6dfaa76e64574a5e0db/w/ed2afaf5bd2d12066495dc84/e/a71ff51699ae36f356a38f690
Point derive F.S. - Very handy, Thank you S1mon. You never disappoint.
May you record and post here the video where you import the stick from "to be derived" part studio into "domestic" Part studio and align sticks so the holes are coaxial and the long edges are paralel?
Here is the document:
https://cad.onshape.com/documents/cf8792c868ef408c458e9f15/w/67bd501bdb12f967c26ba47b/e/6590b32fed338fce64629c67
