Mates Problem - Groups Error message
in Drawings
Hi folks
I have been trying to assemble the drawing of a simple steam engine. I seem to be having Mates Nightmares. I have discovered that using too many Revolute Mates gives rise to the error message "Mate over-defines assembly". It seems that the solution is to swop one Revolute for a Cylindrical Mate. So far so good. I then discovered that parts that had been successfully 'Fastened' the previous day were quite happy to go into free fall the next. Apparently the answer to that is to assemble a few parts (successfully) and then 'Group' them into a singel object. Great idea, so as soon as I got to do it I have discovered a brand new error message; "Mate cannot be added between member of same group". Basically it seems that the bolts I had installed with no complaint earlier do not like to be Grouped.
The assembly has now descended into a mess which is to be found here:
I will leave it up for a while but when I get time to draw again I will need to start from scratch.
I would welcome your ideas and suggestions.
Regards
Pete
