Help do a cut extrude on a airfoil body
alper_kayar
Member Posts: 4 ✭
I am trying to cut a circle in a wing airfoil body but I receive the following error:"Extrude didn't generate properly, Boolian operation failed. When I create a simple body like a cube it works fine. What am I doing wrong here?
Here is the url to the file: https://cad.onshape.com/documents/de35c77a5b9458645840df3f/w/4228e1108ba4825439b02396/e/b4a3a0bcaf968ab8c1fa5aed
This looks like a bug. Make sure you open a ticket.
In the mean time, use the Split feature and split the part with your cylindrical surface.
RENDERCAD
