Help do a cut extrude on a airfoil body
I am trying to cut a circle in a wing airfoil body but I receive the following error:"Extrude didn't generate properly, Boolian operation failed. When I create a simple body like a cube it works fine. What am I doing wrong here?
Here is the url to the file: https://cad.onshape.com/documents/de35c77a5b9458645840df3f/w/4228e1108ba4825439b02396/e/b4a3a0bcaf968ab8c1fa5aed
  • MichaelPascoeMichaelPascoe Member Posts: 2,804 PRO
    edited February 2024
    This looks like a bug. Make sure you open a ticket.
    In the mean time, use the Split feature and split the part with your cylindrical surface.
    RENDERCAD
  • alper_kayaralper_kayar Member Posts: 4
    Thanks Michael.  That helped.  :)
