Please make the document public, it's an edu account so it's private by default. We can check it out. I've never seen the pdf export not be perfect, and I've done hundreds of them.
https://cad.onshape.com/documents/de77294d91c3abfb53a6532d/w/d6b496b6edee9504bfbf1be1/e/f99b3ddf034988c316b03461
https://cad.onshape.com/documents/522043f68a3761dd81778183/v/99f6de5fc6afd219effb4228/e/235bfa06a081ac9b74142e42
What does it look like when you open mine?
@nick_papageorge073
This one has all the dimension that are needed.
The 50mm dimension in your drawing is maybe useful for understanding the design intent, but it isn't something that you would normally want to inspect. It could make sense as a basic dimension if you were calling a profile tolerance on the R15 edge/surface.
https://cad.onshape.com/documents/522043f68a3761dd81778183/v/75977e6fcd59fe8dce4e4bed/e/235bfa06a081ac9b74142e42
