What's the process if I need to edit an Inserted part?
Sometimes I Insert a part and need to modify it, for example cutting it shorter.
Do I need to Derive that part into my own part studio?
Can that be done from the assembly instance of the part, or do I need to search for it with the Derive feature?
Also, is there any way to change the Name or Appearance of Inserted parts without any physical modifications?
dirk_van_der_vaart Member Posts: 560 ✭✭✭
Since you are having an EDU account I don,t want to spoil your day but this is what your teacher can find in your document, in Onshape every document has unlimited history, also importing parts and even Part studio's.
https://cad.onshape.com/documents/44ebd861ddb9841558cc30c8/w/27ecba75d1d4ef9ee3244364/e/8250c1ccf25596adff0f0d22
Go back to the Part Studio and edit your part there.
Also remember that parts that have a relation to each other , put both parts in the same Part studio
A derived part can be modified to suit your different requirements.
Very useful to make other bolt patterns or to suit machining of castings and the like.
https://cad.onshape.com/documents/850adf21db9fda20bc67ee6f/w/d472803dbdf1b0468df1a3b0/e/61418a45404db9f9e1edb3f5
Sometimes I Insert someone else's part into an assembly only to discover later that I need to modify it. I would like to be able to select a part in an assembly and click "Derive into Part Studio" rather than going to a part studio, clicking derive, and then finding the part I need again. Is this possible?
Also, is it possible to change the appearance of someone else's part that has been Inserted into my assembly?
All that said, that's quite convoluted. I'd probably make a copy of the original part studio from your classmate, and modify it as needed, since it would be mine at that point. It will be completely independent of the original.
If you are in your Assembly and want to edit that part, RMB and select Switch to Part studio .........
This will be there for all the free accounts. Will not be there for edu or paid accounts (unless the owner turns it on).
