Generating flat patterns from rolled profiles
 scott_walker796
                    Member Posts: 5 ✭
scott_walker796
                    Member Posts: 5 ✭
                    I am looking to somehow derive measurements of a rolled section of material, so that I may laser cut its blank size while flat to then be rolled to the finished design. I can model the finished part but don't know how to "flatten" it so that I can take measurements or generate a drawing to put into the other tool pathing software for laser cutting.
https://cad.onshape.com/documents/44ebd861ddb9841558cc30c8/w/27ecba75d1d4ef9ee3244364/e/f2fe50046a6f0638773949a7
https://cad.onshape.com/documents/728cdc12963545ec1d3d10e1/w/b49176ac2469d0f5e27eef99/e/d33e5866408864e4a52424c4
In this file, if I've done it right, the green part, because of its variable width on the curve, what it would look like if flat instead of rolled into a ring.
Use the 'extrude' option in the sheet metal part and extrude 'up to face' option. You'll need a split in the sketch so it can be unfolded, in other words the sketch should not be a complete circle
(The flat view is on the sheet metal TAB on the right hand side of the screen)
https://cad.onshape.com/documents/d09021b0a6960f6f5b3e1aa6/w/980268d2b3009f40b9c93c3a/e/f8c889fcfc6ad4fbc82e749a
https://cad.onshape.com/documents/bf0d38e31ac6e25eb8cab1a7/w/85910e4f7f77de943f8b793e/e/b3798844fe462ea51d131f33
