Is it possible to create an non horizontal/vertical (angled) ordinate dimension?
StephenGStephenG Member Posts: 367 ✭✭✭
From what I can determine there is no option to set the datum zero orientation to an angle other than vertical or horizontal.
I want to create ordinate dimension with respect to a edge where the edge/line defines the coordinate system for the ordinate dimension.
The following graphic is what I am after....
Is the above possible?
    mahirmahir Member, Developers Posts: 1,292 ✭✭✭✭✭
    I never had a need for this, but no. It doesn't seem like this is possible. Even if you rotate the view, ordinate dimensions remain horizontal/vertical. Sounds like a good candidate for an improvement request.
    geoff_phillipsgeoff_phillips Member Posts: 4
    Great idea. I would use this when doing diagrans of stairs.
    daniel_pinto240daniel_pinto240 Member Posts: 6
    I really need this.
    martin_kopplowmartin_kopplow Member Posts: 286 PRO
    I have used that in the past and am surprised it isn't available in OS. The old CAD simply accepted a local coordinate system (about equivalent to a mate connector) or a line at any angle as input. Useful.
    Andrew_NethertonAndrew_Netherton Member Posts: 18 PRO
    I'm just discovering this isn't possible now, and have come here for answers.  Looks like I'll keep looking.  One would think this would be an easy improvement.
    pmdpmd Member, Developers Posts: 63 PRO
    @Andrew_Netherton As a workaround you can add a Mate Connector onto the part and re-align the secondary axis to one of the edges. Then view-normal to the the Mate Connector (from right click menu) and create a named view. You can then insert that named view into a drawing which will show a rotated view so vertical and horizontal ordinate dimensions will align with the edge.
