Double draft
asgeir_arnevik
Member Posts: 7 ✭
Hey everyone, I'm trying to use draft to widen this halftube, as shown with the blue arrows. The draft starts at the blue arrow to the right. But i want to do the same thing on the inside, to make it look as demonstrated with the red arrows. I tried drafting again on the inside, but the draft fails, so i am out of options.
Daniel_Kane
Member, Onshape Employees Posts: 31
I was able to do this with 2 drafts, check out this document . I used a semi-circular profile for the pipe though. If yours is more complex do you mind sharing a link to your model?
nick_papageorge_dayjob
Member, csevp Posts: 1,036 PRO
https://cad.onshape.com/documents/8c000e2e3e5594ecd06d99be/v/6dfe1528c6c73fa46605672b/e/dd33fd24098aaea30496809b?renderMode=0&uiState=65caa1f13a62837281c402e4
