How to create a unique paper size in drawings?
OpenR2OpenR2 OS Professional Posts: 188 ✭✭✭
I want to make an E or F sized drawing. Is there a way to generate an empty drawing with certain dimensions? Or do I have to do that by going to a 3rd party software and creating a blank dwg file and then import as a template?
  • OpenR2OpenR2 OS Professional Posts: 188 ✭✭✭
    I see how to make a new drawing interactively but you can only pick standard sizes. Is there any plans to let the user type in a specific paper size?
  • PrachiPrachi Member, OS Professional Posts: 262 ✭✭✭
    Very much need custom sheet sizes. Working with large 1:1 scale print outs for customer. Custom drawing formats directly in OS would be nice but more important to have full scale print outs.
  • MaximumMaximum Member Posts: 2
    I agree with Glen, I often need to have 1:1 sheets for dxf to send out to laser.
  • brennan_natolibrennan_natoli Member Posts: 17 EDU
    It would be great to be able to create custom drawing sizes. A must have for the CNC and laser. Any thoughts Onshape???
  • PeteYodisPeteYodis Moderator, Onshape Employees Posts: 554
    We've had custom sheet sizes for 5+ years now:
    Improvements to Onshape - May 24th, 2017 — Onshape
  • elliot_scully847elliot_scully847 Member Posts: 2 EDU
    the issue with changing the number of columns/rows is that you need to have the border enabled, this causes extra work when using a laser as you have to then remove the border manually after
  • wayne_sauderwayne_sauder Member, csevp Posts: 610 PRO
    If you are dealing with CNC cutting why not send the DXF from the face of the part? (skip the drawing sheet.)
  • dirk_van_der_vaartdirk_van_der_vaart Member Posts: 555 ✭✭✭
    RMB on the face you want to export and select export DXF, same for flat pattern,s
