Post-Assembly Part Modifications
I'm designing an electrical panel that consists of terminal blocks and other components mounted to DIN rails. My initial DIN rail lengths turned out to be excessive; I want to trim them. When I trim them in the Part Studio, all of my mate connectors and mate connections in the assembly become invalid. To make matters worse, when I split the rail, delete the unwanted portion, and insert the truncated part into the assembly, the mate connectors on the part don't load into the assembly despite being visible and seemingly legitimate in the Part Studio.
Is there a way of modifying parts after their inclusion in an assembly that doesn't sabotage the work done to that point?
I don't know if it is relevant, but the parts in the various Part Studios are .stp files imported from vendor sites. I didn't create them from scratch.
Here's the document:
https://cad.onshape.com/documents/80c1a68c3965fe9f436c0423/w/7ea8d439ae06a28edd20f504/e/5ead67fbec2b503cfb243411?renderMode=0&uiState=65c6b7a80076e87eaf244dd6
https://cad.onshape.com/documents/5a56d0fc6e3a4c1ef4a69d5d/w/d24fa242bf188391198f32b6/e/7ed7865e42aa52c89030314d
https://cad.onshape.com/documents/5a56d0fc6e3a4c1ef4a69d5d/w/d24fa242bf188391198f32b6/e/563629663b98a0f5deee6092
