How to make drawings on Ipad
srinivas_psrinivas_p Member Posts: 2
Hi.  I am trying to prepare drawing on Ipad in Onshape application.  I am not able to get "Create Drawing" option on my Ipad.
  • S1monS1mon Member Posts: 4,048 PRO
    From the help: "You can create a drawing on iOS devices, however, the only actions you can take on them in iOS is rename, change the drawing URL, delete, and export."
    Basically you need to use a desktop browser to do real work on drawings. You also can't collaborate at the same time on
    drawings. Both of these limitations seem to stem from the fact that drawings started as a module which was purchased from another developer.
