Best Of
Re: Use Report, viz(), and dbg() for conditional println and debug visualizations
@Derek_Van_Allen_BD That's kind of you to say. I hope that if you start using Report you won't need to scrape it out — you'll be able to leave (at least some of) it in, and just disable it for your users, while re-enabling it when you have to fix something weird that they've done ;)
There are a few other niceties, for example, viz() only adds visualizations, dbg() only writes to the console. The standard library sometimes does both, a behavior I do not care for.
Anyhow, give it a whirl. I use it constantly now in my own code (first step is always "import Report"). I'm curious if others will find it to be as useful as I do. @GregBrown and I were using it to debug some code he's working on, and I think he saw the value of being able to write all the debug he wanted and being able to selectively enable/disable/reenable as he went.
jnewth
@jnewth thanks so much for creating and sharing this. It is proving invaluable in a current project I'm working on (as you know!) which otherwise was full of numerous messy debug and println's…
My surface tweening feature is over 2000 lines of code but most of it is diagnostics as I build the core logic.
I wonder how much of that I could scrape out of there using this.
I literally just stumbled upon the other video this morning! Great work!
ry_gb
Re: FRC CAM Studio Feedback Thread
I don't like how the Toolpath setup choices forget your last selection.
Re: Where are all the places to discovery feature scripts?
There currently isn't a good place to store custom features for easy visibility.
But we could change that if enough people vote on this: Feature Store (Improvement Request)
Here is a list of all the different places you can find custom features:
- by @MBartlett21
- by @dave_cowden
- by @MaxWestwater
- by @Caden_Armstrong
- by @Keith_Rice
- by @EvanReese
- Custom Features Collection PDF by @legandras
- by @MichaelPascoe
- by @onshape
- by @joshtargo
Re: flat pattern x and y size calculator featurescript
I sell a library of computed properties - contains a bunch of common computed part properties such as bounding boxes and flat pattern bounding boxes (along with things like bend count, thickness, face count, longest edge, etc).
Dynamic Frame / Pipe Profiles 🆓
Automate your workflows! CADSharp specializes in custom features, apps, and workflows to speed up your daily routines.
Here is a Dynamic Frame / Pipe Profile that you can copy and use for frame libraries.
- Stabilizes downstream references even if you change sizes.
- Dynamically updates profile data for cut list.
- Choose profile display units.
- Cutlist+ allows you to add this data to your part names or descriptions.
Would be cool if the default frame library also had something like this @NeilCooke.
On a side note, for anyone needing the frame's to properly show up in the assembly bom, you can use Assembly Imposters (Feature + App).
Re: Curving text
@colin_haycock Yes, you can totally do that. What you are asking for is "kerning" which for various reasons is hard to make work the way you'd want (which is: automatically). The feature provides that control via "Adjust offsets":
When you enable "Adjust offsets" a point manipulator appears on each letter (the white dots). You can click on the letter you want to move and drag it left or right to position it:
And tweak letters in this fashion until you are happy with the result.
Hope that helps!
jnewth
