Is it possible to export an individual mesh as its own file?
seth_cones
Member Posts: 2 EDU
I was sent a .stl file, but it is not compatible with Vcarve CAD software. I was hoping to resave all the meshes in the .stl file to a different format so it will be compatible, but I am having difficulties. Is it possible?
NeilCooke
Moderator, Onshape Employees Posts: 5,923
No, it is not possible. You can only create an STL file from a solid part.Senior Director, Technical Services, EMEA5
