Change dimension
Jiaxin_Hao
Member Posts: 3 PRO
in Drawings
When i change the added dimension's data,because of some reason, it is different with the old, it will display a line, but i don't need the line, can i delete the line?
NeilCooke
Moderator, Onshape Employees Posts: 5,971
The underline means “not to scale” and it cannot be removed. Onshape drawings will always measure the exact value. If you want to change it, you must do the change in the part studio or assembly.Senior Director, Technical Services, EMEA6
