Line Constraint from same Plane
famadorianfamadorian Member Posts: 390 ✭✭✭
If I have two vertical parallel lines which are equal, what is the constraint called that makes them start on the same plane?
Thanks.
  • NeilCookeNeilCooke Moderator, Onshape Employees Posts: 5,952 image
    Select the vertices and use the Horizontal constraint
    Alternatively, if the plane in question is not horizontal, you just make their endpoints Coincident to the same angled reference line.
  • famadorianfamadorian Member Posts: 390 ✭✭✭
    Of course;) Thanks
