Hole depth
D8_StarpacD8_Starpac Member Posts: 49 ✭✭
In a C beam I need a hole on one side, if I give through hole mean the opposite side also get cut. So the end of the hole have to determine by upto face and can’t change angle of drilling tool tip.
  • michael3424michael3424 Member Posts: 759 ✭✭✭✭
    Post a link to your document here, if it's not proprietary - that will make a lot easier for the community here to help you.
  • brian_bradybrian_brady Member, Developers Posts: 505 EDU
    Vote for the improvement request to allow holes to be made "up to face" instead of just blind or thru.
  • D8_StarpacD8_Starpac Member Posts: 49 ✭✭
    edited September 2018
    This what I want
    https://cad.onshape.com/documents/c205e7b9ac950f2b8b4a76ea/w/f9932a2e2cbcf3071f40762c/e/ed1573ec57007e31d484f47b
     I want a second hole not like first one
  • lemon1324lemon1324 Member, Developers Posts: 228 EDU
    Until "up to face" holes get implemented, is there a reason simply setting the hole to a blind hole a few mm deeper than the C-channel thickness wouldn't work?
    If the channel thickness might vary significantly you could use a variable to set both the thickness and hole depth so they update together.
    I'm not sure what you mean by adjusting the drill point angle--even though setting a "blind" hole type requires a drill point angle, since you're actually drilling through the first side, the point angle shouldn't matter.
    Edit: for reference, the IR that @brian_brady referred to is here.
    Arul Suresh
