Issue importing .IGS file into Onshape assembly
chase_woodhamschase_woodhams Member Posts: 1
I have no clue why this is happening but when I import a motor IGS file it shows as an individual part but imports into the assembly oddly
If you look at the second image I have uploaded you will notice two small circles in the front of the drawing.... That is what it keeps importing. Also if you look at the import menu you will see that is what it says the "parts" are...
    @chase_woodhams Please use the ? menu and select Feedback to send in info about your issue. Posting bugs here usually lack the important details we need to help solve these issues.  I will look for your ticket.
This discussion has been closed.
