Sheet Metal Cone
kent_henderson
kent_henderson Member Posts: 71 ✭✭✭
My world revolves around blow pipe so sheet metal fittings like segmented elbows, Tee-Wyes, square to rounds, etc. I know this isn't where Onshape shines yet. And I probably struggle with this more than I should. What is the easiest way to do a sheet metal cone 36Ø to 18"Ø x 24" tall? The link is the aforementioned as a surface. https://cad.onshape.com/documents/31e74c1cfcf618e5e1b92b4d/w/4729d47a0a7ce052732858af/e/abadd0913450663a1b58944b
I need to unfold this.
